junkyard question
RE: junkyard question
ORIGINAL: 91stang
do i hear an echo???
ORIGINAL: randy78045
Get a fluidyne... bolts right in.... then add a pusher fan to it... problems solved...
Oh, an if you have underdrive pulleys get rid of em...
ORIGINAL: 5IVE.OH
I would look at the thermostat 1st, then maybe at water pump and rad. My stock rad with an elecrtic fan does the job great.
stat and water pump are new less than 500 miles on both
ORIGINAL: PONY GUY
yes you are correct lincoln Mark VI have a doulbe core but their are 3 core rads out now I thinkg later cobra rads are 3 core aswell
what years and will it just bolt right up with no problem? I have the black magic fan.
no no underdrive pullies. between this and my charging issue im about ready to sell the stang. Its driving me crazy. im going to post a bulliten about the charging issue as soon as i post this.
I think 87-91will work if u have charging issues you needa Ho alternator 75 amp alt is just junk with eletric waterpump and fan I got a 200 amp alt works just fine for me
Sounds like your radiator may be plugging up, take it to a radiator shop and have it checked out... Normally they will check it out for free in anticipation you'll buy a reamed (rebuilt), $50-$100... Also, if you got a clutch fan, if it's wearing out, it will give you the same symptoms... If you buy from a junk yard, you may be buying an already plugged up one...
I got my 3 row radiator brand new from my work (Parts Plus franchise). Go to your local auto parts store and tell them that you need a 3 row radiator for your 19XX 5.0 mustang. Mine works great and looks great. The best part is that it was only like $164.00 .
but if i bought one at an auto parts store i would want a better one. I only buy interior pieces at junkyards, just kinda curious what is better and what will bolt right up. It would be nice to find a 3 core aluminum rad that will bolt right up then i can go down to autozone and get one (i get 20% off).
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
