drag radials, pros and cons of top sellers???
RE: drag radials, pros and cons of top sellers???
If you notice on the tire size they give you a recommended wheel width, i.e. 6-8 inches. That is where you need to start. There are usually different heights (circum.) of tires that will fit on the recommended wheel width. I hope this helps.
yea thats what im doing, im picking up the extra set of rims tomorrow, i wont be running DRs all the time, only to at and from the track. just to make sure i get it... 235 is the tread(or surface w. these i guess) width, 60 is height, and 15 is rim... correct?
damn dude, doin all the work for me, thanks bro. if i get the bfgs im gonna be able to order them from tirerack and get them in a day or two(its based in DE, and i live right out side of DE) im leaning toward the MTs tho, and if thats the case its gonna be either summit or jegs and longer to get to me.
