leaky radiator....
leaky radiator....
quick ?... dont have the money for a new radiator right now,will next month, tired of seein a small puddle under my car every time i park it.. can i use that leak stopper stuff in my radiator??? will it hurt antything inside the block, buildup or whatnot??? i used it on my old honda and it worked.. but this car means a hell of alot more to me then that one....
RE: leaky radiator....
I would avoid the stuff like the plague.
The stock replacement radiators from Schuck's / AutoZone / etc. are usually the best deal price wise.
I have been cooling my low compression 408w with a HD 2core for several months now. It works very well.
Good Luck,
jason
Good Luck,
jason
ORIGINAL: jameswehner
Or if you have a local junkyard try there.... Im sure you can pick up a rad for cheap. Where are you located? I have a stocker I will sell for $30 if your local...
Im in Hamilton, NJ.
Im in Hamilton, NJ.
Dont use the chemicals, they trashed my moms entire coolant system. If its a small leak you can take a pair of needle nose pliers and pinch the fins together where it is leaking. That should hold u over until u can afford a new radiator. My brothers has held up for well over 6 months now.
I picked up a new stock style rad. at advance auto parts for something like $86(and the ends arent plastic so they wont crack)
Oh yeah check to make sure its not just a worn hose or faulty radiator cap b4 u go and buy a radiator. My car was leaking and turned out to be where the lower hose clamps to the radiator. Just a small crack but the mess sure adds up
all new hoses, waterpump gasket, leaK coming from the lower portion of the radiator itself, so its the radiator, ill try advance autoparts, then autozone, just till i get the money and the mods for a better one... thanks for the inputr by the way
