Anyone in the 12's and under on N/A?
#22
RE: Anyone in the 12's and under on N/A?
i am.. 12.3 on 302 bored 60 over edelbrock rpm heads ported,,10.5 comp..domes.typhoon intakecrosswind...holley 670, roller rockers comp cam 512 lift 244@50 electric fan, 100 shot 3000 edge racing stall aod beefef up..shift kit ,manual vb..355 gears on street tires..soon slicks and gears..i have stock susp ... 85 stang 3165 w/o me in it..
#23
ORIGINAL: grabbem88
it needs something don't it......hell look at the outside.
-P.
#24
Best time to date is an 11.91 @117.23 MPH (N/A) and a 10.76 @128.42 MPH With a 250 Shot
ENGINE: Stock Block Bored 0.030, Stock Balanced Crank, Stock Balanced Rods w/ARP Wave-Loc Bolts, TRW Forged Aluminum 11.2.1 Pistons Speed-Pro Rings, BBK Aluminum Pulleys , Jon Kaase Aluminum 247cc Heads, Jon Kaase 3/8" Pushrods, Harland Sharp 1.6 Roller Rockers, Lunati Hydralic Roller Camshaft (242/252 Duration @.050, 560/576 Lift) Trickflow R-Series Intake Manifold, FRPP 75mm Throttle Body, C&L 76mm MAF, BBK 1 5/8" Longtube Headers, BBK 2 1/2" O/R H-Pipe, Flowmaster 2 Chamber Exhaust, Nitrous Express Wet Nitrous System With SHO Nozzle (Adjustable Up To 300 hp)
ELECTRICAL/FUEL: MSD 6AL Ignition w/3 Step Module, MSD Pro-Billet Distributor, MSD TFI Coil, MSD 8.5mm Spark Plug Wires, Autolite #3921 Plugs, FRPP 24lb Injectors, FRPP 255lph Fuel Pump, Aeromotive Fuel Pressure Regulator
DRIVETRAIN: G-Force T5 Transmission, Pro 5.0 Shifter, McLeod 500 Series 10.5" Clutch
Stock 8.8 Housing w/Welded Axel Tubes, FRPP 4.30 Gears, LPW Differential Cover w/Axel Tube Braces
Strange S/S 31 Spline Axels, Strange S/S 31 Spline Spool
SUSPENSION/CHASSIS: UPR Adjustable Caster/Camber Plates, Stock Springs With Two Coils Cut, Stock Shocks, UPR Pro-Series Adjustable Upper & Lower Control Arms, UPR Full-Length Subframe Connectors
WHEELS/ TIRE MODS: Weld Racing Pro-Star Wheels (15x3.5 Front) (15x10 Rear)
Mickey Thompson ET Drag Slick Tires (26x7.5 Front) (28x10.5 Rear)
ACCUAL RWHP: 325 (N/A) 567 (250 Shot)
ACCUAL RWTQ: 330 (N/A) 621 (250 Shot)
#25
I fully expect to go at least 12's or 11's with my new 347 stroker setup, w/ suspension, new drivetrain, everything is new, if i dont get 11s or so im going for novi 2000 or KB and that will do it,
#26
ORIGINAL: grabbem88
or motor, or tranny, or mirrors, or doors, or supports, or headlights, or interior, etc. etc. etc.
#28
498..nhra rules under 500 cubes
ORIGINAL: Chuy1988
Sweet! Chevys kick *** too. What car/motor do you have running in the 8's?
ORIGINAL: 2 kwik
I'm in the 8's all motor but it's a chevy
Aliate X
01-22-2005 05:34 PM
