Tire pressure recommendations for Races...
Old 10-05-2006, 12:14 AM
tinman
tinman's Avatar
Default RE: Tire pressure recommendations for Races...
Just what tires are you using?
tinman is offline
Old 10-05-2006, 12:16 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Me? Nitto Dr's
PRO50SC is offline
Old 10-05-2006, 04:11 PM
203Mach1ne
203Mach1ne's Avatar
Ohh I thought any tires it would be beneficial, my bad
I have Nankang NS-IIs, so even if I run 25 psi in the rear it would be just like running 32 psi--no difference?
203Mach1ne is offline
Old 10-05-2006, 04:23 PM
88stangaruu
88stangaruu's Avatar
25psi i alot considering ive ran 12psi in my Mickey's before...gripped like hell to. I could nail it in every gear Just like i like it.
88stangaruu is offline
Old 10-05-2006, 05:05 PM
LCBlackDep183
LCBlackDep183's Avatar
personally i would put a chain and weight set on the rear and maybe some snow tires...
LCBlackDep183 is offline
Old 10-05-2006, 05:38 PM
203Mach1ne
203Mach1ne's Avatar
ORIGINAL: LCBlackDep183
I dno, but somehow I'd rather do something freer and simpler, like letting out some air
But if its not gonna help at all I might as well forget it---will it help at all?
Old 10-05-2006, 05:47 PM
sgt50
sgt50's Avatar
Too lazy??? WTF!!! How much work do you think it would require? I thought only chevy guys were lazy.
sgt50 is offline
Old 10-05-2006, 05:52 PM
5speed GT
5speed GT's Avatar
ORIGINAL: PRO50SC
Dropping pressure in street tires will do nothing
As impressed as I have been with your knowlege, I have to disagree... when you air down any tire it will widen the contact patch of the tire, so in a way make the tire itself wider, more contact area means more traction. I took off .4 of a second going from 32psi to 15psi the same day, back to back runs.
5speed GT is offline
Old 10-05-2006, 05:53 PM
freewilly
I ♥ Acer
freewilly's Avatar
ORIGINAL: and1bbaii7
Hey guys, normally I run 32 PSI all around, but I was wondering what is the best PSI to run in the rear wheels before a race...
Maybe like 28? Not sure, what do you guys do?
on stock radials it makes no diff. on drag radial i got 20/ 22 for my dot slicks i run 14 psi
freewilly is offline
Old 10-05-2006, 06:00 PM
grabbem88
grabbem88's Avatar
a street tire is a harder compound rubber/yes contact patch can be manipulated,but for refference sake...any geared/high hp. car will blister stock tires. what you did was make a flat tire with weak sidewalls rotate slower<decrease wheel spin,and made your car dangerous.
ORIGINAL: 5speed GT
ORIGINAL: PRO50SC
grabbem88 is offline
Quick Reply: Tire pressure recommendations for Races...
