Tire pressure recommendations for Races...
#31
RE: Tire pressure recommendations for Races...
ORIGINAL: PRO50SC
Thanks Art, As I said, it will do nothing for a street tire. I took almost a full second off my et going from a street radial to a drag radial. My car spun all the way through 3rd on street tires.
5speedgt, dunno, maybe your car doesn't make enough power to need a set of dr's and street tires suffice for your application.
ORIGINAL: grabbem88
a street tire is a harder compound rubber/yes contact patch can be manipulated,but for refference sake...any geared/high hp. car will blister stock tires. what you did was make a flat tire with weak sidewalls rotate slower<decrease wheel spin,and made your car dangerous.
ORIGINAL: 5speed GT
As impressed as I have been with your knowlege, I have to disagree... when you air down any tire it will widen the contact patch of the tire, so in a way make the tire itself wider, more contact area means more traction. I took off .4 of a second going from 32psi to 15psi the same day, back to back runs.
ORIGINAL: PRO50SC
Dropping pressure in street tires will do nothing
on another note, do you ever go to the DC area? I was up right under DC about a month ago and thought I saw your car
#32
letting pressure out of street tires does nothing????
I must be in a twilight zone or something....because i let the pressure out of my BF Goodrich T/A radials and let the sidewalls bulg a little....well i noticed they definatly gripped better and i ran .3 faster on that run. So, maybe im an exception.
Those were 255's about a year ago.
P.S....before someone bitches me out for running low pressure on the street's, i refilled them with a portable tank before i drove home, the last thing i need is a sidewall failure at 70mph on the highway.
#34
ORIGINAL: 5speed GT
^thats the same thing I'm saying, I have BFG T/As also and I took off .4 from my 1/4... but everyone had me second guesing myself.
Yea, i can tell ya, as im sure you already know, a BF T/A is about street as a street tire gets. But i could even feel how much better it gripped, i mean it wasnt as good as a slick by any means, but it was better than a fully pressureized
For one thing....letting pressure out of a LOW PROFILE tire wont do sh*t but make it a danger to everyone near you, low profiles like the slide off the rims with low pressure.
Any tire with a decent side wall and it bulges out a little with low pressure is going to grip better than a pretty low profile tire anyday.
P.S.
And if letting air out does nothing for grip...then why do they tell you to do it when it snows?
#36
I am gonna play with the tire pressure in the hoosiers im borrowing. my 225s spin all day. I dont know about you guys... but I have never been to a track that did not have an air station somewhere in the pit area.
ccdguy
09-19-2015 05:20 PM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
