cylinder head
cylinder head
Hi everyone,
what did you think about the gt-40x cylinder head
do you think I can get better head for the same price
when i will get the maximun power with the gt-40
and when i will get the maximun power with the gt-40x
thank you for your answer
RE: cylinder head
GT40xs are decent, but you can get a better head for the price. If I remember correctly, they sell for $689 a pop out of jegs, which adds to $1380. For $1380 you can get a set of AFR165s or Twisted Wedges for that, and they're much better. I'm pretty sure your power band will stay the same if you don't change your cam.
RE: cylinder head
You can get TW's for 1050 and they are world's better than the X heads. AFR's will run you 1275 shipped from c-f-m.com. You will need stud mount rockers. Scorpions are excellent quality for the price and I would look at the TFS stage 1 cam or a custom grind. I have the E and it's okay, but the letter cams are older technology. Do a lot of Google research before you buy...don't take our words for it....see for yourself so you know you're making the right decision.
RE: cylinder head
ORIGINAL: jsred89
I will change my cam and i'm looking ford ford racing B-303
and what will be themid-range with the AFR head ????
RE: cylinder head
^^I agree. Say you go w/ the TFS track heat...You'll want a cam that operates in the same range (1500-6500rpm) and, if you plan to rev past 5500, you'll want to make sure the valve springs can handle it. AFR's have a problem w/ valve float above 5500, so you'll want to upgrade the springs if you decide on those....
