SN95 body, foglights on only
I have been looking at some pics, and seen some sn95s on the road, and i have seen them with with foglights on and their headlights off, on my car (94 gt) i can only turn on the fog lights only when the headlights are on, could somone please explain how to make the foglights functional without the use of headlights?
RE: SN95 body, foglights on only
I just read a page on how to do this a couple of weeks ago. It was on cardomain somewhere. It was fairly simple to do. You have to take the console apart and splice a couple of wires from the headlights and fog lights. Just do a google search.
there are two ways to do it, you can have them so they can be on with the parking lights or just on by themselves. I have them turn on with the parking lights, you do not have to cut any wires at all. Here's the write up, only takes a few minutes.
Fog Light Wiring Procedure
1. The first step in performing the rewire is to remove the bucket from the center console. Underneath the console lid, there are rubber bumpers on each side of the pullout cup-holder, which must be removed. Under the rubber stops are two phillips head screws. Remove these screws and then remove the bucket. If you can’t get a firm hold on the bucket, you can use the cup-holder to pull it out.
2. With the bucket out, you should be able to identify an eight-wire harness adjacent to the parking brake. Unplug this harness. You will be working with the end toward the rear of the car, which houses female connectors and slides into the other harness plug.
3. On the side of the harness there is a red tab. Use a flathead screwdriver to push in and up to remove the red center divider from the harness. A pair of needle-nose pliers can help remove the divider.
4. With the red divider removed, the gray tabs adjacent to each individual female connector can be pushed toward the center of the harness. With the gray tab pushed to the center, the connectors can be pushed out of the back of the harness. A flathead screwdriver works great for this. You can use the edge of the blade to push the gray tab toward the center of the harness while pushing straight down to force the connector you are working with out the back of the harness.
5. The two wires you will be concerned with are the red/black and blue/red. Use the above procedure to remove these two wires from the harness and switch their positions. These two wires are positioned across from each other and should remain that way, only in opposite positions.
6. Reassemble the harness and plug it back together. Your fog lights should now come on with your parking lamps and the switch is still active.
Result:
Result:
check the bulbs... most bulbs don't lanst for more that 48 running hours unless you get factory style replacements.. if not do voltage drop test from the switch to your lights and make sure your getting voltage to them
