I broke my car tonight...
#21
RE: I broke my car tonight...
ORIGINAL: PRO50SC
It's pressed in and held on by the w/p impeller and a bearing. The shaft and the pump are 1 unit.
Once I get my new pump will I have to have the new shaft pressed in?
#26
I think that was just a freak thing. Dumpin' the clutch should not have caused that. I would however check your motor mounts. If the one on the drivers side is broken, it could have let the motor come up and the fan hit the shroud and caused what happened.
#27
ORIGINAL: PRO50SC
#28
ORIGINAL: PRO50SC
#29
ORIGINAL: ZachW04Stang
I'd think the shroud would go if this happen. I ran into a similar problem like this once. THe fan got a little chewed up but the shroud didn't survive.
ORIGINAL: PRO50SC
#30
i feel ur pain..i was driving to school at 6:45 in the morning n i hadda take my stang b/c my jeeps brakes r out and on the way there whhile i was about to turn onto a busy road my car got stuck in second gear...the shifters in nutral but it stays in second even wehn the shifters in nutral...its standard
