What is needed to run 12's on my 94 gt?
It's a 94' GT conv. 5spd.
-3.73 gears
-BBK cold air intake
-bbk 70mm TB
-full MAC exhaust(no cats, egr delete)
-MSD ignition
-kyb shocks/struts, eibach lowering springs, upper/lower control arms, camber plate
-short throw
I am on Mach1 wheels and street tires right now.. will probably be buying some nitto DR's
What should I get to put my car into the 12's??
I thought about a wet nitrous kit, but I want to run 12's on the motor alone
How much will a intake manifold w/ bigger MAF help?? Since I already got a 70mm TB?
-3.73 gears
-bbk 70mm TB
-MSD ignition
-short throw
RE: What is needed to run 12's on my 94 gt?
u want natural power, heads are the only way to go,
Id do heads and headers, camshaft. 1.94 is the largest valve size that will clear the piston reliefs.
.550 LIFT AND 240 duration is the max with stock size 1.6 rockers you may go on a cam
alright thanks
Which heads/cams/manifold should I buy??
a guy I know is selling gt40 heads and a comp cam for $500
will that and a new mani do the trick??
http://cgi.ebay.com/ebaymotors/302-F...QQcmdZViewItem
thats too much money
gt 40's cost $250 used and cams are lik 150.00 new, no that will not do the trick, thse heads will give you 35 hp over stock and the cam another 15. nothing you will feel
ORIGINAL: aode06
Are you saying he won't feel 50 extra hp?
OP, I'd just buy nitrous.
