belt with no smog
RE: belt with no smog
I cannot remember what size mine is but you can do this. Get a piece of string and route it around the pulleys...then measure how long it is. Take that length to autozone or whatever and tell them you need a belt this length with this many ribs.
On mine I removed the smog pump and A/C compressor but I retained the A/C style power sterring pump bracket, also my crank pulley is an underdrive. I run a 69.5" belt. If you have the stock crank pulley and the a/c still on Id guesstimate that youd need something around 75"-80". Make sure you route your belt correctly when you do this, its VERY easy to get your WP turning the wrong way.
-P.
-P.
This is an odd thing. You're better off finding a piece of string & routing it, then checking it. My friend removed his smog & got the same size belt as me, but it ended up being 1.5 inches too short. Then again I also put a 3g alt on, so it could just be me...
autoedit
09-27-2015 06:37 PM
