Blew up my 94' 5.0
10-06-2006, 11:10 AM
Blew up my 94' 5.0
Ok so last night at 3am I was horsin' my 94' GT around and I heard a quick shatter and then a clunck and my car died... after rocking my car for about an hour, I broke the motor free and got it running... I knew my motor was done, becuse oil had gone everywhere and I suspect I threw a rod out the block as I only made it another mile before the car simply wouldn't move any farther. My question is... since I'm going to replace the engine now.... CAN I ONLY USE A 5.0 OUTTA OF A 94'-95" GT??? It makes it kinda hard to finding one.
10-06-2006, 11:16 AM
RE: Blew up my 94' 5.0
I'm pretty sure you can use one from any 87-95....since the intake manifold is a little different on the 94-95s you'll have to reuse it (they have a slight bend in the neck, whereas 87-93 are straight.
10-06-2006, 01:12 PM
The Godfather
Any 5.0 block will work, but you will have to reuse your intake and maybe your heads, although I'm not 100% sure on the heads.
10-06-2006, 01:34 PM
The intake and timing cover are different. The heads are the same.
10-06-2006, 01:38 PM
isnt the stuff that bolts on the front a little different also? If so you could just reuse your old stuff.
10-06-2006, 01:44 PM
yep, just order any "5.0 long block" and move your intake and accessories over to new engine.
10-06-2006, 01:49 PM
how many miles were on your car, and what were you doing to make it blow ?
10-06-2006, 02:26 PM
The entire short block is the same as any 87+ mustang. But as they said the intake/accesories are pretty much different. So thats going to be reused.
10-06-2006, 02:30 PM
You can use ANY 302. Period. You will have to change out accesories (ps pump, alt, etc), intake, oil pan (depending on what the motor is out of)etc.etc.
-P.
10-06-2006, 02:37 PM
^^^^ Yea, he's right on.
Just generally when you do the swap your aiming for a 87-92 short block with the forged pistons. At least i would be.
