5.0 temps
5.0 temps
I'm fairly new to the mustang, but I have a 95 GT that I have put AFR 165 heads on, trick flow intake, full exhaust and the basic other bolt on things. What worries me is the idle temps. At an idle for a short time the temps will reach 210-225. I have even installed a manual gauge to be sure. Is this normal, should I just monitor the temps and keep driving or is it dangerous. Any advice is apprecitated.
RE: 5.0 temps
Something isnt right there, you should be getting to 225...thats bad...your going to warp those aluminum heads doing that.
You may have put the head gaskets on backwards or your Tstat is stuck closed.
Or it sounds like your radiator isnt up to snuff, maybe an electric fan will fix your problem...find one out of a SN95, those work great.
RE: 5.0 temps
From 5.0 mustang: "We all know that factory gauges aren’t the most accurate, but they can still tell us a lot about how the car is running. Most pre-’94 Mustangs like to run (water temperature) between 190 and 200 degrees F, which translates into the water temp needle being at or around the M or A in NORMAL. SN-95s like to run a little hotter."
RE: 5.0 temps
replace t stat with a 180* fail safe, flush/fill coolant system with fresh 50/50 mix and verify concentration with guage, burp system real good, and then check temp. Also sounds like the fan clutch isn't working properly, may want to get a replacement or upgrade to electric fan on a manual switch or linked to ignition switch so when the motors on the fans on...jmo good luck
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
