tire size ?
tire size ?
well i need new tires to pass inspection (dammit MD), the ones on it now are 225-60-15... what else would fit?
and also, im gettin DRs aswell...will 255/60/15s fit in the back? and what about 275/60/15...
RE: tire size ?
Yes, 255/60/15s will fit fine. I'm assuming that you're going with the MTs. Keep in mind that those tires are 27.10 inches in height, which will effectively raise (lower numerically) your gear ratio. 275/60s are 28 inches tall, which would make this even worse. If you don't have the high reving, high horsepower, low gear car to take advantage of a taller tire, then I would recommend going with a 26" tire like the 275/50/15.
RE: tire size ?
+1 on the 275/50/15 (exact tire size is 25.6")
Dimebag, i'd like to introduce you to an old thread, which has a very inforative post in it... by me!
https://mustangforums.com/fb.asp?m=947990
RE: tire size ?
this tire **** is a headache... what DR size should i go w. then? i was thinking the 255/60/15s, but if your saying that not good... what should i go w. im either running MTs or BFGs maybe 225/50/16?
and also, stock the tire height is 60(talking about my street tires i need to buy too)... but i just read another thread about ppl using 40-45... is that a better idea? or should i stick w. xxx/60/15?
thanks for the quick help...
RE: tire size ?
I run a 275/50/15 BFG DR ona 15x8 Draglite. Seems like the 86 wheels are 7" wide though. That would be pushing it for a tire with a section width over 11". They do make a 235/60/15 DR that is advertised as 26" tall. I let math nerd Adder work the exact measurement out. I would guess it's right at 26" if not a tick smaller.
