k memeber help
RE: k memeber help
I just insalled one on my 84 a couple a nights ago. The actual install of the K member was easy, except for getting the springs back in. The main problem I ran into was the bushings for the rack and pinion did not fit the QA1 K member. I had to bore the steel sleeves that are in the bushings out .100". I got that on and then the tie rod ends that came with my summit rack did not fit in my spindles. I went to the local parts store and got some stock ones for my year model. I will find out tonight after work (I work nightshift) if this will fix my problem. I want to find out if anyone else has run into this same problem.
wentw1tj5773
07-14-2007 06:41 AM
