Electric fans...
Electric fans...
So now I'm thinking since I can't afford to replace my motor mounts right now an electric fan will be the best way to go to avoid my mechanical fan hitting the shroud when I torque the motor....
So...I have next to nothing as far as money. What are my cheapest options? By next to nothing I mean like $40...Thanks
RE: Electric fans...
Go to the junkyard and get a taurus fan and wire it up to a switch inside the car that you can turn on when it starts getting hot. Then when more money comes buy the painless wirring kit that has a temp sensor and relay and all that. I just got a tarus fan today for 25 bucks.
Okay...what year taurus am I looking for?
TrplWht - I'm just going to wire it up to a switch to flip on and off for now. Do the taurus fans bolt right up?
ORIGINAL: primetime5.0
save the money for motor mounts, replace whats needed instead of making it faster
When you replace the motor mounts you will feel a bigger difference then taking the fan clutch off. I have my fans wired through switchs , tried the relay setup was a pain and used a cheap thermostat that would kick the fan on to late.
Im pretty sure that the stock fan will bolt right up bro, i can help you if you want. I did the same thing in my escort, wired it straight up to a switch in my dash. just make sure that your coolant gague works so that you dont "forget" to turn it on, lol.
I just installed a Lincoln Mark VIII fan in mine.
fit like a glove and works like a charm, cost $50 with 30 day warranty from junkyard.
hooked it up with a 30amp relay from radio shack and it just comes on with key.
