? the little groung wire on the neg battery post
Old 10-07-2006, 11:24 PM
1BADASSLX
1BADASSLX's Avatar
Default ? the little groung wire on the neg battery post
hey fellas, i have a ? the little grond wire thats on the neg post of the battery and bolts to the inner fender with a fuse case on it!!! do any of you know what that goes to? well i relocated my battery to my trunk and cut that wire and now im havin some problems with it and sould i run a wire off it back to the battery?
1BADASSLX is offline
Old 10-07-2006, 11:31 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: ? the little groung wire on the neg battery post
I believe it's the ground for the ecm!
PRO50SC is offline
Old 10-07-2006, 11:37 PM
1BADASSLX
1BADASSLX's Avatar
well i out a test light to it and its grounded, but should it be hooked up to the battery for more grounding help (lol) ???????
Old 10-07-2006, 11:38 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yes, I ran a wire from my bat up to where it grounds on the fender when I moved mine to the trunk.
PRO50SC is offline
Old 10-07-2006, 11:49 PM
sassy7806
sassy7806's Avatar
as long as your battery is grounded to the block.you can run it to the block just the same.
most cars have this wire is to keep the static to min.
sassy7806 is offline
TfcCDR
09-14-2015 12:08 PM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: ? the little groung wire on the neg battery post
