My car POPS through intake and that sucks
#31
Did this problem get resolved? Popping / Backfiring from intake
Hi, Did you get the popping / backfiring problem fixed? I have the same problem with my 90 GT. Under a heavy load, it will backfire through the MAF. Does happen every time I give it moderate or full throttle. Any info would be appreciated!
#32
RE: Did this problem get resolved? Popping / Backfiring from intake
what happens to combustion if the intake valve is open too long?
It comes out the intake.
Adjust those valves and check for proper timing
#33
Thanks for the reply aode06. I should have given you more details.
I have a 90 GT with stock ET7 heads and stock stamped steel non-adjustable rocker arms. You may be right about the TFI module being faulty - I'll replace it andcheck the timing again. If I can find a fix for this, I'll post it back here. The problem doesn't happen everytime I try to accelerate with moderate to full throttle though; so maybe it is igntion timing-related? Except a cold air intake, and equal-length shorty headers, the engine is otherwise stock.
Hey, I'm open to any other suggestions or thoughts while I check into this.
#34
I say lean all the way. Intake backfires are the product of a lean condition or a cam timing issue (given your plug wires are routed properly and base timing is not too retarded). Why it is running lean will be your PITA without the right equipment.
#35
I got it resolved. The TFI module was bad. When I checked the timing, it would fluctuate (yes, I did have the shortout plug disconnected). Foolish me, I never though about ignition timing! Thanks all
#37
At first, the timing was at 14 deg, then it changed to 10 deg after I
revving the throttle. I revved it a couple of more time and it
was at 12 deg. Then, the timing mark was actually walking while I
had the engine idling, even though the distributor hold down was
tightened.
I changed the TFI module, reset the timing to 14 deg and it stayed!
I have since:
-Swapped on a set of AFR 185 heads (large chamber)
-FRPP F303 cam with new roller lifters
-FRPP true roller timing set
tightened.
I have since:
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
