losing compression
losing compression
question guys, i diagnosed my car and found out that my car is running lean and losing compression because of my o2 sensors. I have an o/r h-pipe and i wanted to know if i would have to buy the mil eliminator, new o2 sensors or both.
RE: losing compression
I think your diagnosing your car wrong, o2 sensors will not cause your car to run lean unless you have another problem. Also losing compression has nothing to do with the o2 sensors. If you are loosing compression there is about 3 places your loosing it, at the valves, head gasket, or piston wrings.
ORIGINAL: 95BOSS302
it is from the piston rings, but if i have to replace the o2 sensors, can i just get a mil eliminator?
the diagnostic read that the car is running lean from the o2 sensors, i came to a conclusion that the computer makes the car lose compression just so it will run when it is lean, so all i have to do is replace the o2 sensors?
uberstang1
09-20-2015 06:42 PM
