Emblem
Emblem
I bought emblems that arent stick on, but i filed down the posts so that i can stick it on. I had double sided thicker foam stuff from 3M but it didnt work and the emblem fell off. Anyone know what stuff to use??? I know its not the right section but i posted in detailing as well.
RE: Emblem
double sided tape from 3m should work just fine...make sure you prep the surface first...use grease and wax remover to clean the car as well as the emblem...place the emblem on the car and hold for apox 30 seconds with good pressure, then apply tape over the emblem for a couple of hours to make sure the double sided tape has time to adhere
RE: Emblem
where are you trying to stick them? did you clean the area your sticking to with rubbing alcohol as well as the part? what kind of 3m tape did u use? I deal with 3M on the industrial side quite often, try finding a 100 or 200 High Performance Acrylic or else go to an auto body supply store and buy some auto badge tape.... they'll probably have a VHB double faced tape for you. Good Luck, prep is the key to adhesion!
