Well I just poured in some seafoam.
#41
RE: Well I just poured in some seafoam.
Samseed, I guess you have a really clean motor! I also did it when I first got my 93 with 84K on it and it barely smoked at all. BUT I used it on my interpid with 30K and it smoked like a b*tch for like 10 mintues. I also used it on my friends jeep and he smoothed out his idle alot and the car revved alot smoother after that... it definetly works. Different people may experience different things but it does work. So far Ive used it on a 97 Jeep, 88 Stang, 93 Stang, 00 Intrepid and a 2000 Jimmy.
#42
so if you pour it into your fas tank to clean your injectors, does it matter how much gas u have in it? and do u just drive it normal after? thinking mine need a good cleaning
#43
Well some older Fords had a Teflon film in their intake manifolds. I just remember hearing from one of my instructors not to spray carb cleaner or anything in some older Fords. Because it will brake loose the Teflon and gunk up the engine. This probably could be the smoking problem then.
I agree with aode. I have used that Mopar brand on my Jeep when the TB was solid black. It shinned it like new. I would have loved to have seen the inside of my engine after that.
I notice that when most people say "I pour it in my brake booster and don't notice any smoke." Are you actually pouring it in the brake booster or the booster’s vacuum line?
#44
i use it in my gas tank only. it works excelent as a fuel stabilizer (stabil is crap believe it or not), and does a good of job as any other over the counter fuel cleaner. for small engines the best thing to do is run the engine for a while with seafoam in the tank and run it out of gas and store it like that for the off season, it wont varnish or gum up that way. ive done it for years on my lawnmowers, atv's, and snowmobiles. i learned it from an old mechanic that used to own a local atv dealership. he worked on machines for many years and its all he would ever do to his.
i use a quart of tranny fluid before an oil change to flush the engine. i had an old 78 f150 with a 400 in it and i used seafoam in the oil, it smoothed the idle out and made the engine run a little better. it has some gummy lifters in it and it cleaned them up alright.
i later bought a 79 f150 with another 400 in it and used tranny fluid, it cleaned more gunk out and the engine ran better for longer, its also about $4 cheaper.
some of the old street rods guys swear by slowly dumping a cup or 2 of water down the carb, they say it does the same thing as seafoam (it cleans the carbon off the same way, cold touching hot and steaming it). i have never tried it so i cant say it works or not.
#45
i heard that two,and my uncle has done it in front of me...he used a spritz bottle..
hey you are good with 400 go to live chat need to talk more about my 400
#46
ORIGINAL: Foxy5.0
#48
Yeah, that's what happened to my Mustang when i did it. I thought maybe I screwed something up so I went out and bought another can for the Hyundai Accent. That thing smoked out the entire corner of my street! So I know I did it right. I guess my engine was as clean as I thought it was. Although I should have known... everyone says that the water / meth injections really help clean up the interior.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
