Ok your turn to help me out!!
Anyone know where I can get a mounting bracket for this cut off switch. It doesn't come w/ one![:@]
http://store.summitracing.com/partde...5&autoview=sku
Thanks
Thanks
RE: Ok your turn to help me out!!
I have a very small trailer hitch that runs from the bumper mounts side to side. You can barely see it. I need an l bracket to bolt it up to the frame of the hitch.
if i was you... i would get one of those old school gm liscense plate brackets that use to flip down so you could put gas in the car and then drill a hole behind the liscense plate for the switch and just fab up some small metal brackets that will hold the frame away from the car by like an inch so when it's folded up there is like an inch or so gap behind the liscense plate. you cann have the switch behind the plate and then when you need to shut the battery off just flip down the liscense plate and flip the witch and then put the liscense plate back up. never even know it's there. just MHO.
You know that's a really good idea! it's just a lil more than I feel like doing though. Not sure if that would pass tech cuz it would be hidden.
yeah.. lol.. time sucks. Anyways pro. i think you are gonna have to fabricate a mount bracket up yourself to make it work like you want... or maybe buy a aux switch panle from summit or jegs or something and customize it yourself to make it work.
