Oil Preasure
RE: Oil Preasure
On my stock gauge, my oil pressure only drops less than one line when idling. When the revs are up a bit, it's at the line above the middle line. I can't wait to install my gauges tommorow and find out what the pressure is really doing.
Oh, and my stock gauge has never gone anywhere near all the way down.
RE: Oil Preasure
its normal to fluctuate but dropping down to nothing isn't the best... its a sign the oil pumps on its way out, i've read that minimumally you need 10psi per 1000 rpms but those are forum numbers, not from a tech article or magazine. I'd look into dropping the oil pan and inspecting the pump and pickup. good luck, i wouldn't feel comforatable below 30 psi at idle and wann have50-55psi at WOT.
RE: Oil Preasure
I agree that its a good possibility that its the gauge BUT even if it was bad/innacurate it still shouldnt drop that low... I guess get a new gauge and try it out. BTW, all my gauges work perfect lol
