head work
RE: head work
ORIGINAL: Liquid_02
It's an 86, has flat-tops
ORIGINAL: 88BlueGT
You dont have to notch your pistons with all heads... only some. Like AFR 185's, etc. and other larger heads.
Ah hah... thanks liquid!
RE: head work
ORIGINAL: ih8chevy
alrite i mite be able to find some people but incase i cant how do i determine where to notch the pistons
RE: head work
ORIGINAL: ih8chevy
it is so should i get the 93 comp my friend has one a drunk driver hit him and his car is totaled so will his comp do its a gt 5 speed
RE: head work
You dont HAVE to switch but it would make things alot easier on yourself if you did.
Also, i h8chevy, your compression ration really depends. It depends on what kind of fuel you want to run and it depends on what you want to do with your car. If you want to go NA you can go something in the 11's and try to still keep it on pump gas and if you want to go with a SC/turbo you can try to get it into the 8's.
