head work
RE: head work
I would get somebody who knows what they're doing to do it, as no offence intended, you don't sound like you do, and you could REALLY screw something up easily by notching the pistons. Notching them basically is what it's called... you notch them... cut a little divet in them so they have a valve relief
RE: head work
Yah that'd work. Basically it's cutting a slot in the top of the pistons so when they're at TDC and the valves are open, the pistons won't hit them. Just you have to be careful when notching as you can't have a sharp edge as it will create a hotspot on the piston and burn it out, as well as you have to get the notches in just the right place
RE: head work
b/c i m gtting the afr 165cc heads and i wont have too much more to spend and i was also wondering if i can keep them fuel injected or do i have to switch to carb cause i dont want to
RE: head work
ORIGINAL: ih8chevy
where can i get the info on the net to do this stuff
Here's a picture of a notched piston to show you what I'm talking about.
Yah, they can stay injected, they're made for the injected cars afterall, but I would suggest carb... you're going to have LOTS of computer problems with the old 86 SD system
