what size injectors does a 95 cobra have???
Old 10-16-2006, 01:51 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default what size injectors does a 95 cobra have???
i need to kno asap.. i order a maf and im not sure the guy was rite... if his not i can chew him a new hole but hten it would take more time... which i dont ahve... so yea... what size.... for sure... not i think... or at least how can i check??
CrazyCobraSpeed is offline
Old 10-16-2006, 02:39 PM
samseed101
samseed101's Avatar
Default RE: what size injectors does a 95 cobra have???
You may want to double check with someone else, but I think they're 19lb injectors. They're color coded so you should be able to tell fairly easily. Yelklow ones are 19#s.
samseed101 is offline
Old 10-16-2006, 02:53 PM
95_302_StangMan
95_302_StangMan's Avatar
They should be 24's
95_302_StangMan is offline
Old 10-16-2006, 03:06 PM
7upedition
7upedition's Avatar
99% positive '95 cobras came with 24lb, call ford dealer and ask what stock replacement is, or call one of our sponsors and they'll know! summit or jegs customer service will know
7upedition is offline
Suspect
Suspect's Avatar
i thought the same ^^
Suspect is offline
Old 10-16-2006, 03:14 PM
7upedition
7upedition's Avatar
http://fordfuelinjection.com/files/How_MAF_works.doc
"Stock 5.0 and 4.6L 2V Mustangs were originally equipped with 19# injectors. The 5.0L / 5.8L and 4.6L 4V Mustang Cobras came with 24# injectors."
confirmed they came with 24lb injectors! yahtzee [8D]
Old 10-16-2006, 03:15 PM
88BlueGT
88BlueGT's Avatar
+1 Yes I always thought that they came wiht 24's.
Is that what the guy told you?
88BlueGT is offline
Old 10-16-2006, 03:17 PM
CrazyCobraSpeed
the guy said 19#'s i think... so you sure there 24's cuz thats kinda what i thot.. but he said 19... if you sure there 24s ill call him bak
Old 10-16-2006, 03:21 PM
88BlueGT
88BlueGT's Avatar
I always though so..... but I would read the article posted by 7up to comfirm. Looks like he did that already though. Call ford for a 100% sure answer.
88BlueGT is offline
Old 10-16-2006, 03:27 PM
CrazyCobraSpeed
the article says 24# for 5.0 5.8 and 4v cobras like 7up said... i guess that page is a relieable source... is it trustworth site u think??
Quick Reply: what size injectors does a 95 cobra have???
