car still vibrates! What the F???
RE: car still vibrates! What the F???
When you say you put a solid balancer on what do you mean? Solid like new? Solid like cool? Solid like there is no rubber compound inbetween the outer ring and inner ring?
Is the new balancer the same weight as stock? Is your flywheel the same weight as stock?
ORIGINAL: Foxy5.0
have you tried to make sure you have the right flywheel, cause if you had a new balance put on and it wasnt the same weight as the flywheel then that will cause a vibration. i had a vibration in my car when i switched motors and it turned out to be the flywheel. pre 1981 blocks require a different flywheel cant remember if its 28oz or 50oz. give that a shot
yeah, when I ordered it, I asked at least 5 different places to be sure, and researched so that I got the right weight. My mechanic told me to make sure 100% before ordering. It vibrated before I did the clutch and flywheel though, so I pretty much ruled that out. I did check though.
Somethings way outta whack. Your balancer mightve been misboxed. As in a 50oz mightve been boxed in the 28oz. I work in the parts business, misboxing happens, not a lot but it does happen. Id say try putting on your FACTORY balancer and see if it changes. Maybe you need a fluiddamper.
-P.
-P.
ORIGINAL: Ninety5five0
I donno if a tune will help out vibration at all, but a tune will give you alot extra. How does it run without a tune ?
ORIGINAL: mpswirl
i had a problem with the clutch fan and my car shook extremely bad until i changed the clutch fan.
So, I guess the cheapest route would be to go get a stock balancer and see if it does anything. If not, I return it and pray it's my mounts. I already have stock mounts, so I'll put them on. If the vibes are still there, I guess I'm f##ked and have to look for a new bottom end.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
