vibration
vibration
i have an 89 lx hatchback and when the car gets to be around 100 mph or so it begins to shake a lot but doesnt do it at any other time. A friend of mine who knows alot about these cars thought the driveshaft might be loose and thats why but when i checked it it seemed fine. i havent seen him again to ask him about it so I was wondering if you guys might have any ideas why it could be doing this.
RE: vibration
Have you changed the gears?
Bigger gears tend to require a better drive shaft.
The balance of the driveshaft is more important after a gear swap.
An Al driveshaft from Ford usually fixes the problem, so most folks say.
jason
jason
RE: vibration
I didn't know the driveshaft balance affects the gears? but it does make sense since they are linked together! Good info as always vristang...
I was thinking check alignment and front end bearings and bushings?
RE: vibration
the aluminum driveshaft with the new "high performace" u joints fixed that exact probly in my car
except i was getting vibrations at like 70 mph pretty bad... with 4.10s
pretty cheap.. 4 bolts on/off and youre done
RE: vibration
I have a vibration at 80-90 and I have had tires balanced, u-joints were fine, etc.... Finally found out my driveshaft was bent a little, just bought the FMS aluminum driveshaft and putting it on tomorrow, so I will let you know if that fixes it.
