28. 31 is when you get a lot more hp and need to start worrying about snapping your axel.
Has way more to do with traction and suspension than hp. Launching off the limiter with slicks/suspension on a bone stock motor can tear the axles to shreads fairly easily as well.
I've seen a guy at cecil county drag strip which is a well preped track snap an axle and go into the wall with 14 sec car. If you plan on running slicks I'd upgrade the axles and install c clip eliminators just for safety reasons. They could save you a lot of money in the long run. It think you'll be fine w/ 28 spline but you should probably get stronger axles.
