Ok, get out your guess-timating machines.....
My '66 coupe with a TW headed 306 started knocking down low......the death rattle.......so heres the new project:
1970 302 block
347 kit, 4340 crank, H beam 4340 rods
10.5:1 CR forged flattops
Keeping the Track Heat upgraded TW heads
Trick Flow Stage 3 hyd roller cam
Comp Cams Retrofit Link Bar lifters
Torker 2 intake
Speed Demon 650
1 5/8" long tubes with 3" flow's, after the cutouts
Full MSD setup.....ProBillet, 6AL box, Blaster E coil
High pressure oil pump
Main/head studs
Main girdle
Crane Energizer rockers
13 lb. aluminum flywheel and king cobra clutch
Billet SFI balancer
Tremec 3550 and a Auburn Posi 4.11 8" in the back
M/T 28x10.5 DOT cheaters
And finally......debating which pills to use in the Super Powershot plate system......
Anyhoo, anyone got any magic calculator in their pocket that'll give me any idea on hp numbers? Ive got the Desktop dyno thing, but Ill bet you can guess how much stock I put in that bit of wizardry. Its telling me a little north of 500hp at 6500, but i feel thats a little optimistic. The coupes got subframe connectors and a 6 point cage, so im not worried about taco'ing the chassis on launch. Im just offering up my growing pile of parts boxes on the altar of the car gods, looking for a divine prediction or two. Any and all opinions would be greatly appreciated. Thanks to all.
1970 302 block
Torker 2 intake
Speed Demon 650
Main/head studs
Main girdle
Billet SFI balancer
