Yayy Sea Foam is great!!!
RE: Yayy Sea Foam is great!!!
ORIGINAL: Black95MustangGT
I just did it this morning, its greeeeat.
Put some in my gas tank and my crankcase and in the brake booster. there wasnt much smoke out of the engine, but holy macaronni..alot came out of the exhaust. ALOOOOTTTT.
it was tight.
took the car for a spin and busted WOT. haha
the car idles alot better and this chirping noise i couldnt figure out got a little quiter after it(something with my pulleys). but it fixed alot and it runs and sounds so much better
it was tight.
ok ,.........i think some of us including me are lost??? we need a "how to" on this seafoam stuff you guys are talking about, i read the replys and i can tell it cleans something what fill us in,............whats the deal???
depends how you want to use it. you can pour it in the gas to clean the fuel system, you can pour some in the oils to clean gunk and free up lifters, or you can put it into the intake of a running vehgicle slowly untill it stalls to clean the cylinders/ pistons/ valves.
on a carb vehicle slowly pour it down the carb with the engine running, the engine will start to bog. keep pouring slowly intill it dies, let it sit a half hour and start it up. fuel injection vehicles are the same way unless you cant pour it down the intake (never fords and chevys). for these you pull the brake booster vaccume line from the brake booster and install it there. i use a small $.19 funnel from walmart as it allows me to kill the engine like you are supposed to. if you suck it up and the engine doesnt die there wont be enough to do its job. this is why some people dont see lots of smoke. its the seafoam smoaking not the carbon.
any parts store has it for under $6 a can, i buy it at carquest as its under $5
lol, i need to get some for my brother, and the old engne, new one is well new (go figure) but when my brother blew a head gasket, we found out A. he has alot of carbon buildup, and B. he was running on 7 cylinders. yeah, i should buy some, and use it, and hell come out and be like WTF, is my engine blown. id love to see the look on his face.
69MustangCoupe393cid
10-03-2015 10:33 AM
uberstang1
09-20-2015 06:42 PM
yourmom6990
09-14-2015 10:52 PM
09-08-2015 11:50 AM
