spark plugs
RE: spark plugs
They can look them up for you and show you how to gap them. They will probably try to tell you, "no gapping required" but don't believe the hype. It's ALWAYS a good idea to check incase they were dropped or you need to fine-tune it.
You will need to buy a gapping tool ($5.00) and add it to your toolbox.
RE: spark plugs
I didnt gap my autolite #25's. I pulled the stockers and checked the gapping on them and it was the same as the autolites so I just threw them in. No problems.
Should I of gapped them?
RE: spark plugs
Not saying you should GAP them, just CHECK them. If someone dropped one of the plugs it could close the gap.
CrazyCobra: yes, it takes two seconds for them to show you how to gap them, if not, here's a link to help you.
http://www.mkiv.com/manual/manualtt/gapping/
ORIGINAL: 88BlueGT
RE: spark plugs
i use auto light 25's and have to change them about every 7000 miles with a gap of .045. if you are running factory timeing stick with .054. if you run it hard get used to changing them more often
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
