Trick Flow Top end kit.....
I have the trick flow H/C/I combo with basic upgrade bolt ons, 24lbs injectors, 6AL and such. Whats the best plug I can get, I have been running stock type plugs, would a "hotter/colder" plug be better or should I stay with stock?
RE: Trick Flow Top end kit.....
depends on how you run it. n/a you can go hotter and get better gas mileage and a little better power. this is because more of the fuel will be burned, getting better efficiency out of the fuel and air you're putting in
