cam choice for my mild motor?
Old 10-16-2006, 10:09 PM
blk89lx
blk89lx's Avatar
Default cam choice for my mild motor?
ok well im looking for a good cam for my mild motor. i have cobra upper lower intake, full exhaust, fuel pressure reg, 4:10 gears, 2800 stall converter, cold air intake, 73mm maf, 65mm t/b. with these mods what would be a good choice of cam. heads are later down the road but for now i want that nice rumble. i was thinking an e303 cam. any suggestions?
blk89lx is offline
Old 10-16-2006, 10:19 PM
Ninety5five0
Ninety5five0's Avatar
Default RE: cam choice for my mild motor?
I'd get a cam based on my heads. You should hold off a bit and save up for some cheap heads. Unless you know exactly what your heads are gonna be and what rockers you wanna use, i'd hold off and do both at the same time. You can get some heads for pretty cheap. I got my P's on ebay for 500 shipped with larger valves and .600 springs.
Ninety5five0 is offline
Old 10-16-2006, 10:27 PM
highskewlmustnglvr86
highskewlmustnglvr86's Avatar
im going with a b303.....
tyler
highskewlmustnglvr86 is offline
Old 10-16-2006, 11:06 PM
gspfunk
gspfunk's Avatar
If you want a nice rumble, go w/ a B cam and 1.7's (longer pushrods) or the TFS stage 1 w/ 1.6's. The advantage to the B cam and 1.7's is the longer duration, but the stage 1 has split lift/duration and will run well later when you get some heads, too.
gspfunk is offline
Old 10-17-2006, 12:07 AM
OneFine89Mustang
OneFine89Mustang's Avatar
trickflow stage 1
OneFine89Mustang is offline
Old 10-17-2006, 12:09 AM
Ninety5five0
YAY, that makes me happy, cuz thats what i got. Shes almost done, i can post up a clip of the exhaust when its done, if it ever gets done................
Old 10-17-2006, 12:16 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: blk89lx
If you are interested, a close friend of mine owns a set of worked D0OE heads. They have 1.94 intake valves, 3 angle valbe job, new springs, retainers, rocker studs, everything is all comp cams parts.
Hes trying to get $300+shipping
AdderMk2 is offline
Old 10-17-2006, 12:54 AM
machzilla
machzilla's Avatar
TFS stage 1 did well for me.
Almost the same mods as you but did aluminum heads at same time.
Recently dyno'ed 302 at the wheels, 328 torque.
No drivability problems whatsoever, but really hits a lick!
machzilla is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mrappe
09-26-2015 10:16 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: cam choice for my mild motor?
