17x9's and lowering
RE: 17x9's and lowering
tires are 245/40/17 front 285/45/17 rear....i might have the 40s mixed though.
its the pro systenm plus kit...about 1.5 inches. mine rub in the front when i corner hard but that it...im gonna fix that though
VT89 ,,,, i have a 89 drop top and i lowered it with H&R race springs with my MM road and track box and i got 17x9s w/ nitto 555 275/40/17 DRs on back and Extremes on front, 5 lug convo w/ sn95 spindles and stock rear w/ moser 31 splines, rubs a lil bit on ground effects on front but can cut it so no problem there,, guess i might just be lucky, gotta get rid of the quad shocks out back though
Mine is dropped 1.5" and I have 17x9's with 235x45's all around, it only rubs when in a turn and I hit a bump, no rubbing at all otherwise.
[IMG]local://upfiles/44525/D438E76432B44230BD55291969A50DA5.jpg[/IMG]
i am running 245-45-17 all around i honeslty cant tell you how much it is dropped since it was done when i got the car. I do have slight rubbing on drivers side at full lock.
[IMG]local://upfiles/33894/A6CD688A9161446186DA4386BD1148B2.jpg[/IMG]
[IMG]local://upfiles/33894/30D91FE1BD0D49A887FEABB20DD308AF.jpg[/IMG]
