No torque
No torque
Car is going into ford tommorow so hopefully i wont have to mess with it. but i have no low end torque or hp. i ran the car at the trac and got a 17.4 wtf. I have done a fuel tune up, and cant figure it out. its a 94 vert auto. you guys have any ideas?
RE: No torque
I have a 95 very auto, which is the same thing as the 94 (AODE tranny, same engine, body, weight, gears, etc.) As others have stated, if you are basically stock, then that's not too far off from what you can expect. I would say mid to low 16's. But you can easily reach 17's with a tired engine on bad tires with little to no launch, etc.
I had to do quite a bit to compensate for the problems with mine. Changed to 3.73 gears, added a shift kit, dropped a lot of unnecessary weight, got better suspension, added water / meth injection, added supercharger, added ratchet shifter so it's easier to control my shift points, etc.
RE: No torque
^^ I doubt that... right conditions and where hes located does have an affect on times though. And for the driver mod... its an automatic so its not like he can really mess up anywhere except for launching.
