File Fitting Piston Rings
Old 10-17-2006, 02:40 PM
95_302_StangMan
95_302_StangMan's Avatar
Default File Fitting Piston Rings
Hey could someone fill me in on how you exactly file the rings? Do you use a flat file or do you need some kind of tool.
95_302_StangMan is offline
Old 10-17-2006, 02:46 PM
aode08
aode08's Avatar
Default RE: File Fitting Piston Rings
DONT FILE THEM
they are already checked for you Digitally in a 4.000 bore etc, before its put in the box to specs. when you file, you create blowby, only good for superchargers, Ive tested alot in rebuilds, just put em on the rings and go, this is a old method that becoming useless in todays advancements.
aode08 is offline
Old 10-17-2006, 03:28 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you don't put them in and go you get the ring gaps.....I check 3-5 spots on every cyl for ring clearance and I make sure every ring has the same gap..ie all top rings are the same etc....
2 kwik is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
BeatnikFink
10-01-2015 08:00 PM
fastbackford351
10-01-2015 12:24 PM
mdg
10-01-2015 07:04 AM
Quick Reply: File Fitting Piston Rings
