BALL JOINT PROBLEM!!!
RE: BALL JOINT PROBLEM!!!
The Steeeda X2 balljoints come in pairs dont worry, but if Iwas you while you were down there either replace the control arms the are fairly cheap or at least change out the bushings...also I ighly recomend Steedas bumpsteer kit...I dont know how low you car is....I have sportlines with no problems
Ok thanks alot. I dont have the money right now for control arms. I can take these ones out and put them in a new control arm later down the road? The car isnt to low. I got it like this, so im not sure if they were cut or something. Its lower than most stangs I see. What would you recommend for control arms? And you said you had the Eibach sportlines right? How are they? To low? I live in chicago so im concerned about speed bumps, snow, and pot holes.
trashxtrash
09-20-2015 10:49 PM
ccdguy
09-19-2015 05:20 PM
