MUFFLERS or NO Mufflers...
ok i got a friend saying everyones telling him stright pipes is good to run.. and i my self.. think its hard on the motor and can burn ur valves. what do u gusy think? also i think u loose hp.
RE: MUFFLERS or NO Mufflers...
anyone know?
No back pressure is not good on stock motors.......
Run a muffler at least but you will only get out what you are putting in ( in other words your intake)....more air out only sounds better...you won't gain much HP.....If any. |
ok so more less i was right.
yea u were right
You will lose TREMENDOUS amounts of down low torque, it's not worth it at all on a stock or bolt on 5.0. Dont do it, your buddy is retarded. Use mufflers.
^^ when i first read this i thought of u and ur vert
i am running no mufflers and i have the cats still. the only reason for this is my mufflers where messed up and i was afraid of messing up the motor. i asked a tech before i cut them and he said with the cats it will be no problem. but i felt a big loss in power and it sounds like ****
You will loose low end torque, people think the bigger the exhaust the better, NOT.
Leave the mufflers on, if he's looking to sound cool tell him to buy a fart can honda exhaust... what a dummy... if he's serious tell him to save his pennies and buy a tuned catback from magnaflow, flowmaster, summit even has budget ones for $200! That'd be better then what he's gonna do and yes open headers can cause burnt valves.
