87 MUSTANG DASH AND MARKER LIGHTS INOP
Old 10-18-2006, 02:52 AM
unnatrl
Default 87 MUSTANG DASH AND MARKER LIGHTS INOP
The dash board and marker lights are inop on my 87 GT. I can jump the wires on the back of the dimmer switch and they come on, but nothing works correctly (turn on headlight switch and only headlights come on). I swapped headlight switches with another car and had no luck. Has anyone run into this problem and found a definitive root cause? All fuses are good, I pulled the dash out of the car and traced all the wires to make sure none were broken or cut and all look fine. When I jump the wires on the back of the dimmer all my dash and running lights function like they should. Any ideas???????
unnatrl is offline
Old 10-18-2006, 03:30 AM
dimebag
dimebag's Avatar
Default RE: 87 MUSTANG DASH AND MARKER LIGHTS INOP
havent had the prob but sounds like the ya need a new dimmer switch and possibly headlight switch... if you can take the dimmer switch apart ther should be a coil, and a "finger(or w.e. u wanna call it)" that sweeps along it as teh dimmer is moved... make sure its touching all the time... could be a bad connection in there... either way it seems like you have isolated the prob to being the switches...
dimebag is offline
Old 10-18-2006, 03:31 AM
dimebag
dimebag's Avatar
sorry, not the headlight switch, just the dimmer.
dimebag is offline
Old 10-18-2006, 10:08 PM
LX92envy
Which wires on the back of the dimmer switch did you jump together. I am having the same problem with my dash lights as well.
Thanks,
Phil
LX92envy is offline
Old 10-18-2006, 10:15 PM
03BottleFedGT
03BottleFedGT's Avatar
have had that problem and seen it many times its the dimmer switch you local ford dealer should keep them in stock
03BottleFedGT is offline
Old 10-19-2006, 01:25 PM
blybdas
+1 on the dimmer switch. Had the same problem. Didn't have to replace it though. Just pulled the switch and "worked" with the finger to get better contact. Used contact cleaner on the finger and coil. Worked fine when I finished.
blybdas is offline
Old 10-19-2006, 01:27 PM
88BlueGT
I have a dimmer switch for sale... check my cardomain
3rd page
88BlueGT is offline
daytooday
05-02-2018 05:56 PM
Diode Dynamics
02-28-2018 10:39 AM
1st 4 eyed fox
08-15-2015 02:16 AM
drumhedd2005
08-13-2015 09:59 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 87 MUSTANG DASH AND MARKER LIGHTS INOP
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
