hopefully it gets fixed today !!!!!!!!!!!
hay fellas i have been fightin a rich problem with my 5.0 for about a month now, today im takein it to a good place and there going to put it on a scope has anyone ever had that done? and how much dose it cost!
RE: hopefully it gets fixed today !!!!!!!!!!!
running rich? did you check to se if your Coolant Temperature Sensoe is bad? my car had that problem and was running rich because of that malfunction of that sensor. After i replaced it, it ran fine.
ya i changed that and the air charge sensor, and the injectors, fuel pump, regulator, only thing i have'nt changed was the sensor to the gauge but i dont think that would cause my problems!
Running rich?....as in codes 42 & 92 showing up in a self-test?.....I'm sorry to write this, but you may be taking a "ride"......IYKWIM?......
A scope is simply a DVOM with a graphic display and a faster sampling rate (adjustable BTW).......a tool, not a a magic wand.
