Car dies at idle after hci swap
My car dies when I put it into drive or reverse or sitting at a stop for a while after it warms up, I have to keep the rpms at about 900 other wise it chugs once or twice and eventually dies. I have the e303 cam w/ a 2400 converter, would that be causing it to do that? I was prob. going to get a bigger stall next year anyways (like a 3200).
RE: Car dies at idle after hci swap
Mine did the same thing after I did the HCI swap. I was just posting about it in another topic of C&L tubes. What mass air meter do you have? I have the 76MM mass air meter and I think that's causing the crappy idle and the car to die. When I come to a stop the idle surges up and down for a while until it settles in but if I have to stop hard or fast the idle dives and the car stalls every damn time!!
ORIGINAL: SteveSkal
is it carb,efi.. carb hook up a vacume gauge..or a timing light a timing light is good for wither one..i hada carb,and a edelbrock hci setup and b4 i had timing at idle at -8 degrees ran like a dog after hci change at -8 i had to advance it 12+ degrees after..start at 10 and go from there...and try 28-36 degrees of totle timing ..10-14 idle and 28-36 totle..two diff type of timing..yu need to know both anddo both...
