Still not charging enough
I just got done putting on a 130 amp alternator from a '95 Mustang 5.0 and my car still doesnt charge enough at idle with the lights on.
Ive got underdrive pullies and had a charging issue with them and the stock 75 amp alternator so I got a higher amp alternator and wired it up the right way (used a link in this forum) and now still have a charging issue. I dont have a big stereo or anything else electric to draw away alot of power so whats the deal here? The gauge reads between the A and L of NORMAL. What do I need to do to make this thing charge right? |
RE: Still not charging enough
What is your idle speed? Did you check the threads below this one?
take the underdrives out and your problems will be solved.
have you tested the alternator and battery with a load tester to see how many amps/volts your drawing vs. putting out?
and yes i've heard underdrive pullies can cause charging issues...[&:] |
ORIGINAL: lookin4astang What is your idle speed? Did you check the threads below this one? |
ORIGINAL: black89gt take the underdrives out and your problems will be solved. |
ORIGINAL: 7upedition have you tested the alternator and battery with a load tester to see how many amps/volts your drawing vs. putting out? and yes i've heard underdrive pullies can cause charging issues...[&:] I know the underdrives cause a charging issue but I thought that was only with the stock 75 amp alternator and I thought the 130 amp alternator was supposed to make it ok. Thats the whole reason I bought the 130 amp alternator. |
you need a smaller alternator pulley to speed up the alternator.
I was lucky and had a buddy with one laying around, not sure what it came off of. and I thought the SN95's came stock with a 130amp alt? No? |
ORIGINAL: r.barn you need a smaller alternator pulley to speed up the alternator. I was lucky and had a buddy with one laying around, not sure what it came off of. and I thought the SN95's came stock with a 130amp alt? No? I have a pulley off the '92 alternator, one off the '95 alternator and the underdrive one. Should I just find the smallest one and use it? |
yes, '95's came with the 130amp alternator and smaller pully
