Alittle Help?
RE: Alittle Help?
i rotated the driveshaft around a few times and the universal joints seem like there is little to no play but the car still vibrated excessivly. when i hold the shifter it vibrates really hard so its gotta be something in the driveline... any more suggestions?
RE: Alittle Help?
Did you remove the clutch and flywheel as well? You should index the clutch/flywheel if your reusing them again as they will have mated to each other and can cause a vibration if reinstalled differently then removed.
RE: Alittle Help?
ok then in that case i got no clue... lemme sleep on this one... lol... im tired as shyt and not thinkin right.... my only real guess is that something got put to gether slightly off center or w.e. or ... something could be loose?
Stangsational
12-31-2004 08:55 PM
