Alittle Help?
Alittle Help?
just reinstalled the tranny and now there is vibrations when i accelerate and at rpms above 3gs. i have a feelin it may be the universal joints on the driveshaft or the driveshaft has 8 bolt holes and the rearend only has 4 to connect it to could it be off a hole?
thanks gary
thanks gary
RE: Alittle Help?
well i don't know.. but i'm having kind of the same problem but i feel the vibration or... better yet, the resistance on the gas pedal passed 3k... But i didn't put a new tranny in.. i put a new motor in.. but i'll be checkin in on this post to see what others think
RE: Alittle Help?
tranny in my cars not new i just had a clicking problem so i dropped it to check out another problem i had. its gotta be something to do with the driveshaft because it didnt vibrate b4 i dropped the tranny.
RE: Alittle Help?
ok my guess... either your driveshaft is outa alignment(maybe slightly, and i mean slightly bent), a bad u joint, maybe something off balance... or that new trans has something a lil off internally... also... mighta mounted the trans a lil off, not perfectly... just a lil would do that to ya id wanna think...
