SMOG Q?
I removed the smog tube that was tied to the stock headers when I installed my exhaust. I plugged the inlet tube to my O/R x-pipe by welding a bolt into it. There is a valve that had a hose that came off of it and went to the tubing that went down to the x-pipe. Anyone have any suggestions for plugging this? My check engine light comes on so I assume it is contributed to this.
Also do O2 sensors need to be replaced? R/ |
RE: SMOG Q?
Pull your codes to find out what the computer thinks is worth triggering theCEL for
I suspect you will get more than one code. Yes the O2's are recommended to be changed every 60k miles, IIRC. jason |
