Wich Heads For My Stang?
#51
RE: Wich Heads For My Stang?
ORIGINAL: TeenStang89
Hey you guys im 16 i have a 89 mustang 5.0 i wanna by some heads, im thinking about getting gt40 heads (because theyre cheaper too)i have about 255hp now im looking to get some heads that will give me about 300hp will gt40 heads do it or do i need to look at some diffrent ones ? help me out guys >
Ryan
Ryan
#53
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:EF:US:11
what about these heads ?
plus you cant beat the price
ORIGINAL: Mustangkiler
not sure if those are the gt-40 ps but those are the way to go if your going to go with a cast production 5.0 head, need new headers though
ORIGINAL: gothikka
Yes, those are the heads he's is talking about. The look pretty used so if you get them you might want to put all new valves/springs/seals on there.....at least I would. You might be able to get a good deal on them. I wouldn't go up to $400 but if you can grab them for $250 or under that would be perfect.
when i say new, i mean less than 5k
#54
personally...i wouldnt mess around with buying cheap stuff right away just to get some quick power.....if you could save some cash and do some research id go with a good set..i mean while your there i wouldnt waste anytime or money.....i went with the AFR 165 and i pick up some good power.....but one thing that you want to take into consideration is that heads will open up and give you more power once you do mods...if your N/A yea you could get like 40-50hp with heads but once you blow that 40-50 will turn into 80-90 ontop of another 120+ depending on blower
#55
before you pick a head you need to think how you want the car to run just putting afr's on and not changing anything else wont really do that much for you i personally would go with a set of gt40p heads you can use alot of the aftermarket headers you just need a 90 deg. boot on both ends of your plug wires and with those heads and a fms f camshaft the car would run great imo i had that set up on a 91 with a carb and it went 12:70's at the track with stock suspension and et street radials good luck with your car
