331 or 347?
Old 10-21-2006, 10:20 AM
5.0 MPG
5.0 MPG's Avatar
Default 331 or 347?
Im about to purchase one of these and cant make my mind up. I eventually want to blow it so take that into consideration. Whats the major difference and which route should I go?
5.0 MPG is offline
Old 10-21-2006, 11:24 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: 331 or 347?
351. but wait until R.Barn is finished with his swap so he can tell you how much your looking at so you can make an educated desicion
AdderMk2 is offline
Old 10-21-2006, 01:49 PM
w8less
w8less's Avatar
347 easy. if ur wanting to put a blower it just make sure ur cr is around 8-8.5 and u will be fine. my 347 is set up for boost at well
w8less is offline
Old 10-21-2006, 02:58 PM
FullAuto
FullAuto's Avatar
There is no reason to leave free cubic inches on the table. I'd do the 347.
When you're ready check with me on some kit prices. I can get them for you cheap.
FullAuto is offline
Old 10-21-2006, 03:49 PM
silver91gt
silver91gt's Avatar
go with a 363
347 rotating assembly in a dart block bored to 4.125
silver91gt is offline
Old 10-21-2006, 04:05 PM
r.barn
r.barn's Avatar
347 with boost on stock block will split eventually.
do a 357W...... can build it cheaper and will be MUCH stronger in the long run.
an s/c will take a little custom bracket work probably, but shouldnt be hard to do.
Hood clearance on an EFI 357 is the only real headache.
r.barn is offline
Old 10-21-2006, 04:33 PM
OneFine89Mustang
OneFine89Mustang's Avatar
if you wanna run this on the strip as long as the strip i would do 331
OneFine89Mustang is offline
Old 10-21-2006, 04:41 PM
silver91gt
silver91gt's Avatar
ORIGINAL: 5.0 MPG
the difference is a 331 uses a 3.25" stroke crank, and the 347 uses a 3.4" stroke crank
the 347 will make more power because there is no replacement for displacement.
Old 10-21-2006, 06:02 PM
SSKiller
SSKiller's Avatar
ORIGINAL: silver91gt
ORIGINAL: 5.0 MPG
Actually there is....it is called Nitrous, or boost.
SSKiller is offline
Old 10-21-2006, 06:43 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
i have plans similar to ones u have... i was thinking a dart block bored at 4.125 with a 347 stroker set up for 363 like silver said.... i was then goin to slap a 2.2 kenne bell on it and enjoy the lack of traction thru all my gears lol... plus that much torque would make the ricers around here cry lol
CrazyCobraSpeed is offline
Quick Reply: 331 or 347?
