oil pan question?
I have a '93 stock Fox. I am wondering if I canemove the oil pan with the motor still mounted? Is there enough clearance between the pan and the "A" frame?
RE: oil pan question?
Nope. You have to lift the motor up about 4-5 inches to get the pan out. To change a gasket you just need to lift it a little (can loosen mounts).
