Coolant Level
RE: Coolant Level
ORIGINAL: Boss_Hotrod
If you recently changed to fluid it might just be getting the air out. Back when we changed ours out we had to constatnly add coolant. We quit having to add some after a few weeks. Check for leaks also.
RE: Coolant Level
gget your self a block tester that will tell you is you HG is leaking but it could be anything seaping gasket on intake , on thermostate. water pump , or timing case cover could have a leak behind it and change yoru oil the water might not have mixed with you oil and it could be sitting at the botom of the pan
RE: Coolant Level
ORIGINAL: jody
Oh, I haven't bought a complete gasket set for a while now,(years) is Fel-Pro still the way to go for quality? Mr. Gasket?
jwog666
12-27-2021 08:09 PM
